balamb0776
- Apr 26, 2011
- 5
Okay so yesterday i was trying to fix the problem im having with my control box. Well the dead mans switch in it was messed up and i moved it and when i turned the key it shorted out and now it doesn't do anything when i turn the key after i removed the dead mans switch and connected the wires. I was wondering where the fuses are so i can check and see if it burnt out? Also if not do you think it could have messed up the ignition? I was thinking it is probably a fuse or the ignition battery's are fully charged and brand new only about 3 weeks old.
