Re: Converting motor from cable & pulley steering to rotary
As I said, it isn't going to happen. You could devise a way to move the attachment more toward the steering pivot to shorten the arc, but you will find that the motor won't tilt without interference. So, you say you don't care if it won't tilt. Well, you will care when you hit an underwater object and the motor comes flying up violently. Something is going to break.
Trust me, I worked for years in the dealership trying to make those things work. The best you can hope for is to put up with the reduced steering. Not too much trouble when under way, but try docking that sucker.
