paint code and decal match for 79 evinrude
eaganboater1
I am having a new powerhead put into my 79 evinrude 100hp. Wanting the outside to look as good I was dismayed to find the OMC paint code was discontinued in 1990. Has dupont or other paint supplier created a cross reference code i can buy? I am unable to get a scan match becasue someone coated it with duplicolor white before i bought the boat. also, the engine shroud decals appear unavailalbe ( brown, "Javelin").
Can anyone help?
emdsapmgr
Re: paint code and decal match for 79 evinrude
You can check out the factory parts list for your engine: epc.brp.com/ That has the original paint codes and has the ES number, which you may be able to cross reference for your paint. If you are after the original white color paint, it supercedes and is still available from Bombardier in a 12 oz spray can, under part number: 777178.
