I just bought a 12ft jonboat with a Johnson Deluxe 4.0 outboard on it, and the tiller has what I suspect is an electrical switch on the end of the tiller? There is the twist grip for the throttle, and then a smaller rubber covered twist grip, and then a red plastic thing that "looks" like a button right on the end?
I have not started the motor yet, so I thought I would see if I could find out a bit more before starting it. The seller did briefly start it to show me it runs (only ran for 5 sec so the water pump would not be damaged running dry). However, I did not notice the config on the end of the tiller till I got home.
Also, is there a place that has the owner's manual or a shop manual in pdf I can download?
Many thanks!
Chuck
Many thanks!
Chuck
