I recently replaced the ignition switch. I pulled a few boneheads when I was rewiring it and have had to go back into the control box at least 6 different times now. Here's my problem now, I've got the wiring hooked up what I think is correctly but sometimes when I turn the key to the "on" position, the starter spins!?! I've experimented and sometimes I can turn it to the on position and the starter doesn't spin but I can wiggle the key and when I do it just right the starter will spin!?!?! I'm thinking that I need to replace the switch again, correct?
Second question, can you tell me what the purple wire on the switch goes to? It's on the accessory pole but I really don't have any accessories so I'm wondering if it needs to be connected or not.
Thanks for your help!
