remote mount for 6 hp Johnson
Perquimans
I am rigging a 1968 6 hp Johnson onto a 1955 Alumacraft for my grandkids. (I'm hoping 6 hp will limit the trouble they can get into.) The boat is rigged with remote steering and controls that were set up for a previous 20 Johnson motor of similar vintage, i.e. it has the old shift and throttle lever system. The throttle is easily setup; however, the shift lever cable needs to be offset at the motor in order to shift smoothly. I have seen a motor of similar vintage with an offset that accomplished this objective very well, but have not been able to find one on the web or elsewhere. Any suggestioins?
F_R
Re: remote mount for 6 hp Johnson
380293 Remote Control Adapter kit is required.
wyoron
Will this kit work on 1975 Johnson 6 HP? If not do you know the Part number of a kit that will work. If so where is a place I could buy one. Thanks for any info you have.
Perquimans
Thanks for responding, but when I did not hear something right away I, as a woodworker, devised what I needed out of wood. It works great.
