Re: Fuel Mixture for 40hp Johnson
The cutoff that OMC published in 1964 was 1964; all earlier than that get 24:1, all '64 and later get 50:1. OMC and BRP have both second guessed that a few times, but mostly to change some earlier models to 20:1 and 16:1.
Joe, however , is correct that the 40s (RD series) even as early as 1960 were equipped with all "frictionless" bearings and can probably run 50:1 with no risk. I trust Joe.
I am more inclined not to outguess the maker and would use 24:1 in Models RD-22 to RD-25, 50:1 in RD-26 and later.
All 2 stroke outboards of any age must use TC-W3 rated oils.
