Ok... I've been working on this engine for awhile... and it's running better and better... right now I'm removing the carbs (again) to re-clean them, and check ALL the floats for proper setting. And will be checking/replacing fuel/recirc lines next.
Each time I remove the cover, in my mind I see the photo of j_k_bisson's Evinrude he rebuilt. DANG..!! It is nice looking..!!! My engine cover doesn't look 'bad' considering it's age and use... but, I'm eye-ing it up for some cosmetic work.
Maybe this is the wrong part of the forum..?? But, here goes...
My cover has the 'raised' lettering, with 'pins' on it, that has 'clips' holding the "EVINRUDE" emblems in place. Where can I get some clips..?? Any ideas about how to fix broken pins..?? Offhand, I think I'd try using a small screw with washer from the inside of the cowling...(??) How about the 'tape', the XP 200, and the 'top' tape..?? Is all this stuff available..??
Anyone got a link to the 'OEM' colors for this motor..?? And are THEY available..??
Normally, I'm mostly concerned with how a motor runs... and don't mind a motor 'looking it's age'... but, I buffed up the boat, removed every piece of teak, sanded, put on 3 coats of urethane, polished all the SS, and the boat looks pretty spiffy....
And... like I said... looking the the pictures of Jeff's motor....
