I have a 9.5 Evinrude Sportwin from 1965 that I inherited from my Grandfather. Quite frankly it seems to have been a dog since the day he bought it from what I'm told. Anyway, I'm trying to put it back into service after several years and have noticed two problems. One of them is puzzling and the other is probably just a typical broken or worn part issue.
Problem 1: the lower unit jumps out of gear under power. I assume this is the worn/broken part issue. Is this common, and it it easily fixed?
Problem 2: the bendix gear is plastic, and it seems the flywheel is chewing it up badly. It's almost like it's turning backwards against the teeth and wearing them off. I'm on the second one and it's already looking worn and having trouble engaging. What might be causing this? Does someone make a sturdier gear I could swap into it?
Thanks for any info.
