Re: Racor fuel filter?
Since you replaced all the fuel lines, it is very possible to have an air leak due to a loose connection. The way to check, is to get a clear piece of tubing that is the same diameter as the fuel line that goes to the carb. Start at the top carb, and work your way to the tank. Run the eninge, and look for air bubbles. Should be solid fuel in the lines, NO BUBBLES. You may need different sizes of clear tubing. This proccess can take a while, but it will help to eliminate any air leaks. Air leaks are possible, even if there is no fuel leaking. Check all connections, Do not assume anything. Once you have eliminated air leaks, we can continue further troubleshooting, including checking fuel pressure.
