Re: 1977-85hp Evinrude Carburetor adjustment screws
That explains why the brass screws, under the cap screws, were seated at the bottom. I had to re-shape a screwdriver to fit the head and removed them.
Is it common for these to need replacing? I have the carburetors off and going to clean and rebuild. Should these adj screws be replaced? The overall condition of the carbs are good. no gum any where.
The problem with the motor is that it misses alot.
Things I have done:
1. Put 10 gal of new gas in with Seafoam and Stilbilt . I could not get the old gas out. Been in there since 4 July last year, the previous ower said.
2. Put in new spark plugs. The old ones had a lot of carbon on them.
3. Replaced the fuel pump after I broke the nipple off the old one trying to remove the hose so I could replace it. Urrrrr!
4. Let it run for about 15 min with water mufflers on. Seems to run better at faster speeds and misses at lower speed.
5. Sprayed Seafoam into the sparkplug cylinders and into the carberator- air intake
6. The previous ower said it was rebuilt about 4 years ago when they ran it without oil and was only used at company picknick 4 July. It has 110 written on the two right clyinders and 115 on the two left.
7. At the sparkplug, the metal stays cool to the touch after the 15min run.
8 I did notice, at the needle on the carb, the little spring which attaches to the float was missing.
9. At the moment, this was only on the top carb. I have not gotten to the bottom one yet.
