MrJimbo
- Nov 15, 2010
- 12
I have a 1988 Evinrude 48 hp outboard (E48ESLCCC) and need to know what size/amps circuit breaker to put between the battery and the motor. Help is much appreciated.
Background info: I have had a couple of instances where the motor stalled but the starter kept spinning and I could not turn it off. I removed the key etc. It eventually stopped on its own. I want to put a switch on the starting battery to force it off just in case it did not stop on its own. Since I'm going to add a switch then why not make it a circuit breaker for double duty.
