Removing bad steering cable from a 95 Seaswirl Striper 20' center console w/96 Johnson 130 outboard. I cannot get the cable far enough out of the tilt tube for the end to clear it. I can't imagine they designed it so you have to remove the outboard just to replace the cable.
What is the best way to remove the steering cable on this setup?
