hey guys this is my first boat on this forumn so please bear with me. I am working on a motor for my brother in law its a 120 hp johnson v4 J120TLCUR. He just aquired this and I have installed it and hooked up the forward controls. the promlem I am having now is hooking up the power tilt trim cylinder. there Is a switch for up and down on the throttle coming from it is three wires going to a male spade connection wires are blue/white green/white
RED spades look like this
__ __
__
Coming from the trim cylinder motor is a conectoer with male spades that are
blue
green and look like
__
l
also is a second spade connecter with two wires both are black and spades are l l
under the cowl I have found the trim relay box containing two relays but there are no spade connectores anywhere under the cowl. my question does any one know if it is missing a section of harness or how I can make what he has work. thanks everyone in advanced for anyhelp you may provide. Also the forward controls came with the motor when he bought it
__ __
__
blue
green and look like
__
l
