piston orientation 4.5hp Evinrude 1980
raczekp1
i did the carb job, took out pistons, but i didnt pay atention which side should i put them back.
isnside piston are 2 marks( mark looks like arrowhead, and letter "L")
so "L" means low, and this side down?
jonesg
Re: piston orientation
No wonder you got no reply.
What yr, hp and model engine.
When you say pistons, is that needle valves?
boobie
Better explain yourself better if you want any replies.
Mas
If you're looking at the "pistons," the "L" means loose side to remove the wrist pins...which there is no reason to remove. Still wondering why the pistons were removed? "Carb job" meaning carburator???? Or, "carb job" meaning removing built up carbon on the piston/rings/head??? If it's the later, there is an easier way with products like "seafoam," which do not require powerhead teardown.
Mas
emdsapmgr
The piston only goes back in the engine one way. The dome on the top of the piston must be in a specific orientation. The rod must also be correctly oriented. The small oil hole on the piston end of the rod must be facing upward during reassembly. That makes the rod/piston assembly either a right or a left. If you are asking these questions during reassembly, I'd suggest you get a factory service manual.
raczekp1
i took out pistons becouse i had stuck rings in one piston.
puting back i tought its good idea to put new rings at both pistons.
for me its not posible to get service manual
i'm working with 4.5hp Evinrude 1980,
i think this solution with piston orientation is the same as 6 hp, 7.5 hp, 9.9hp becouse spark plugs are locateg at the same side of head.
SolingSailor
The top of the piston will have two slopes. The steeper slope goes toward the intake ports. The lesser slope orients towards the exhaust ports. If there is an oil hole in the connecting rod, it must go upwards.
emdsapmgr
Yes, I must have been thinking of another engine...sorry for the misleading comment.
raczekp1
Re: piston orientation 4.5hp Evinrude 1980
maybe someone can add some photo, how should it look.
i'm thinking it should look like this one
SolingSailor
That photo looks correct to me. A service manual would tell all.
