Todd Klatt
- Mar 23, 2011
- 3
Hello
I am having a problem with my 1993 evinrude 48 HP. The engine will start/idle fine when I put it in the water. It will run well initially on a plane/full speed but almost without fail will start surging, this is the best word I can think of to describe it. It will very quickly and dramatically lose power, then try to regain power then lose power ect.... When this happens I wil bring to idle and it will still idle fine and when I put it back in gear will run fine at trolling speed but as I bring it up past idle/trolling speed the problem will happen again. (I dont have a tachometer, so I cant give you the RPM's that the problem is occuring at). The thing is, it doesnt happen every time I have it on the water, nor does it happen at a specific timeframe, sometimes it happens after running for an hour, sometimes 15 minutes, its very random. The engine sat for about six months, before I put it back in the water about a month ago. I just had the carbs cleaned and rebuilt. I have also replaced the gas tank/line. I also have been using and additive in the gas, which is suposed to counter act the effects of ethanol. Not sure where to go from here, any ideas would be greatly appreciated.
