I pinched the wire to the shifter solenoids when changing water pump. Now reverse gear not working. My question is can this wire be changed to any wire as long as waterproof connections are made? I looked up the part and it is obsolete and expensive for a wire. Or do you recommend I search harder to find the OEM part?
