I followed the suggestions on another post to test the electrical system.
I got lost in some of the checking of ohms on the coils. I did a test by holding the spark plug and got a jolt on one but nothing on the other.
To test the coil with an ohms meter, what wires should I do the test on? The plate is item (4).
Also I found one wire with a bad connection at the sparkplug and removed 1/4" from both wires and reconnected. I was wanting to check the sparkplug wires under the plate but don't know how to get the plate off. There are two philips screws near the points are these the ones to remove the plate?
On the top coil does it correspond to the wires to the right?
How do you test the condensor?
(see attached)
(see attached)
