Re: Cleaner for plastic carb bowls
The best cleaner I've ever seen is BRP Engine Tuner. You can buy a gallon of it, put it in a bucket and leave the plastic carb bowls soak for as long as you want. Then just rinse off with water and use compressed air. If you forget they're soaking, no harm done.
