I put the new water pump impeller kit in and no water out the tell-tale. Assuming I did something wrong, I dropped the lower unit again and rechecked everything, double checked the direction of the impeller blades and put it all back together again, including that stupid shift rod screw that makes me move the starter out of the way. Still nothing out the tell-tale. Tried it in a drum. Hooked up the muffs and water flows freely thru the tell-tale with the motor off? Maybe I am getting too anxious, the power head is not hot to the touch after a full minute. If it is the thermostat, where is it? Looks like water is leaking from the joint where the lower meets the upper unit. Where do I go from here?
