I currently own an 1967 evinrude (model #80753) it is an speedifour motor (Manual shift) that runs good but I am having problems with the gears (I think).
Here is the issue, when I have the motor in forward gear at idle it will go fine but when I give it some power it will make a clunk noise and lose power for a split second, this clunk is very rhythmic and comes around about every 4-5 seconds. and now if I give it any power when it is is gear it will jump out of gear completely and rev out of control until I shut the engine off. Then after the last time I took the boat out and this happened it leaked a large pool of thick grease on the ground beneath the engine it was yellowish-green in color. do you know what this is from?
Now I have been researching on the web for a little bit and come up with "you are jumping out of gear. The lugs on the fwd gear are worn. A new clutch dog will not correct this. You need a gearset and now another new clutch dog. Been there, done that. It's the only way to correct the issue."
I would like someone to confirm this before I start doing any work to the engine. I also looked up the forward gear (part # 377870) and it is pricey (+$100). I have heard that it is possible to swap the forward and reverse gears, is this possible? When it says lugs is he talking about the washers behind the gears? I do not see the word lug in the parts diagram.
Finally what is all involved in doing this work my self? Can I just take the lower end apart and replace the parts (I have the manual) rather easily? Will I need to replace any other parts such as seals or gaskets?
Thank you so much for any and all help you can provide, I really want to get my boat working again so I can do some fishing this year.
