Crappie_Fan
- Jan 9, 2002
- 105
I'm replacing the cables in my old boat, was thinking about replacing these cable ends. This shifter end cant be right, Its had a Nylon locknut on a regular bolt to go through the shifter lever, the way it is you cant tighten it all the way otherwise the shifter wont be able to stroke. If someone can show me a picture of what should actually be installed on the lever part that would be great.
Thanks
Thanks
