whats the ft lb spec for this flywheel nut? thanks
J joseph1980 Seaman Joined May 27, 2005 Messages 54 Feb 24, 2011 #1 whats the ft lb spec for this flywheel nut? thanks
Cofe Lieutenant Commander Joined Apr 23, 2009 Messages 1,883 Feb 24, 2011 #2 Re: 1985 evinrude 25 hp flywheel torque The manual says 100-105 foot pounds. Make sure it is put together clean and dry. The notch on the key points down. Have a good one!
