Re: 88 hp johnson tip of skeg on lower unit broke off
That lower skeg is really a prop protector. Doesn't do much else. You won't need it, unless you fish in shallow areas and are prone to dinging up the prop on occasion. Most marine dealerships have replacement skegs which can be welded onto the remaining skeg. After some smoothing and paint, you will think it's brand new.
