j_k_bisson
- Oct 6, 2010
- 1,082
Juat a couple questions reguarding my 1987 225hp Evinrude hood and side shields. I want to repaint them. They are in pretty rough shape. The are spider cracked in some places and have chips in them in other palces.
1)What are they made out of? Plastic, fiber glass, or unknown compostite material (backlite, etc)?
If plastic I know what to do. I'm a plastic engineer. If fiberglass what type of resin used to make them? I would like to use the correct resin to fix.
2)What type of primer to use on them? Is zinc chromate ok. I have a ton of it left over from the lower unit pieces. Or is two part epoxy primer better?
I'm planning on using the factory Evinrude paint if that helps the primer question. I have painted cars and trucks before, so I know the prep steps for paint in general. Its just the materials that I have a problem with. Not fimiliar with what this is made out of.
Thanks
Thanks
