I'm new to this forum. Last year I was given a 16 foot 1970 glastron trihull with a 1975 75 hp johnson stinger2 outboard model number 75ESR75B. With the driver and 1 passenger the boat gets up on plane and cruises easily at 32mph. When another 2 adults sit in the back of the boat it bogs down and won't get up on plane unless 1 adult moves to the front of the boat to shift the weight forward. I ran a compression test top cylinder running 85psi middle running 90psi and bottom running 88psi. motor has no trim and has a dolphin installed no clue what brand. It's also running a 17 pitch prop. Any help would be greatly appreciated! Thanks in advance.
