Will a PT&T from a 1973 Johnson 70HP triple carb three cylinder(owner description)??? work on my Starflight Model 135483,
Thanks for any help.
The 73 trim units was 172670 and fit from 65 thru 135 hp. In 74 the 172509 would fit from 70 thru 135. Agree, it should fit.
Just an fyi....
Uh oh, I think that's a power tilt only model....but I wouldn't pay much for it...........
Just an fyi...
The port cylinder is the trim cylinder (up only) and the starboard cylinder is the tilt cylinder(up and down).
I mention this beacause if your bench testing, the trim cyinder only pushes upward a small amount(then moves freely) and uses the tilt cylinder to pull it downward to full trim down position. I've had folks panic when tested, that the trim side seems to be flapping in the breeze.
