Hi guys my evinrude junior 2hp wont star. It has new coil,condensors,pointts and plug. Good spark and fuel seems to be getting in. Only thing is it doesnt have the plastic air silencer? Could this be why?
1. adjust in right way point uder flywheel.
2.make sure that carb is set in right way(slow/speed needle is 1.5 tourn out)
3.check if carb fuel valve is open
4.to start spray some fuel/oil mix in carb throat.
air silencer will not the reason of no start problem
