getballistic
- Feb 10, 2011
- 6
So I was pull starting an electric start Johnson 25 hp with the battery disconnected and key in to simulate a dead battery scenario in the water. Turned over one pull. Problem was when I pulled the rope the spare fuse flew off and lost it somewhere in the yard. So went to checkers to get back up 20 amp fuses These are the glow in the dark ones when they're bad they glow. So I took off the fuse to go checkers. Came back installed new fuse and the original in the spare holder. So two days later figure I'd try pull start her to warm her up and nothing. Plugged in battery and triedbelectric start and nothing either. Checked fuse and it's good. Switched back to original fuse and still nothing. Battery is charged. Bilge pump and lights all work. But nothing at engine. What could I have done wrong?
