Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
85hp Johnson v4 Compression #'s ?
  • 85hp Johnson v4 Compression #'s ?
    So I did the compression test as outlined above I have only had this motor for about a month and havent had a chance to put it in the water as there is about 8" of ice standing between me and it I was just wondering if these #'s sound good or about average for a 1975 85HP Johnson V4 engine.
    Cylinder #1 115PSI
    Cylinder #2 116PSI
    Cylinder #3 119PSI
    Cylinder #4 120PSI
    Thanks for the info guys!
    http://s1238.photobucket.com/albums/ff481/FJ_Russi/
    Re: 85hp Johnson v4 Compression #'s ?
    Sound great to me. From what I understand, the actual numbers are not really that important as the testers aren't real accurate in that regard but they ARE consistant. Yours being over 100 and so closely matched is a very good thing.
    2002 20' Hydra-Sports 202DC 200HP Yamaha HPDI
    1976 18' Starcraft SuperSport 90HP Evinrude
    Restoration thread http://forums.iboats.com/showthread.php?t=357767
    • #3
      Thanks EZ! I was looking for factory #'s just out of curiousity but I coudn't find any.
      So the Starmada does venture out into the world of Iboats. I thought we all just hung out there like a cult or something
      • #4
        Nah, I'm just stalking you
        • #5
          LOL Well I guess thats cool. I mean I always visioned my stalker being 120lbs blonde hair blue eyes and female but maybe we can work something out.... Your not far off that right EZ??
          • #6
            There are no published factory #'s that I know of. As long as they are 15 psi with in each other should be okay. Last time I seen a spec published was in a 1967 Evinrude snowmobile service manual.
            • #7
              ok well then looks like I'm good to go. I was Just do some routine checks and dreaming of spring. Thanks for the info Boobie!
              • #8
                That engine when new probably had close to 125 lbs compression, so your current numbers are just fine. Also, it is not unusual for the compression to vary a few lbs from one head to the other, due to the way the blocks were machined at the factory. Looks normal!
