jrlakeside
- Jan 10, 2011
- 3
there is a tilt trim motor on this engine,have not seen one like this before. it does not work .it has a cable coming from the trim motor going to the right side of the motor.it looks like ther used to be a switch of some kind there.and a elect.wire coming out of the bottom of the trim motor,dont believe that it is hooked up eather.My ? is how does this unit work?is this a manual tilt trim of some kind? please help if you can thanks
