Re: Evinrude Marine Battery
On those, it's pretty easy to tell if there is a generator mounted on it. You'll see it mounted on the port side, opposite of the starter and a small toothed belt running to the top of the flywheel. The electric shift models are more apt to have a generator, than the standard models, because of the electric shifting. In the electrical junction box, you should have a voltage regulator. Of course, the junction box that is set up for the voltage regulator, is a bit larger than the standard junction box. If your motor doesn't have a generator or voltage regulator, it is still wired to take one. I would follow jhebert's advice on the conventional battery idea also.
