I bought a '57 Johnson 7.5 hp for use on my inflatable. It runs great (most of the time), and is a real conversation starter as my wife and I cruise around the marinas. Twice this fall it overhated as I was idling. I noticed it immediately and shut her down. After cooling it started and ran OK. I haven't done any damage to it. It never overheated when running above idle.
I decided to replace the impellor and have it torn down at the moment. The impeller was intact, no missing pieces, but the only thing I noticed was it was quite rigid and hard, not very flexible. It may be quite old, I just don't know.
The teardown was easy, thanks to some of the postings I found on this forum.
I have a new powerhead gasket, but I think I will go back to the dealer and get a new o-ring and cork gasket for the seal at the top of the drive shaft.
I have several questions:
1. How do I hold the powerhead gasket and cork gasket/brass washer in place as I lower the powerhead onto the intermerdiate housing? I can't see in there to make sure all the parts are properly aligned as I lower the powerhead into position.
2. Which direction do the openings face on the water inlet plate? It seems they should face forward and act like a scoop, but somewhere I thought I read that they face toward the rear.
