Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
help replacing shift shaft lever on 1960 johnson 40hp
  • help replacing shift shaft lever on 1960 johnson 40hp
    Hello
    Can anyone tell me how to replace the shift shaft lever that connects to the clevis on a 1960 johnson 40 hp.
    Please help!!!!
    Thanks all
    Re: help replacing shift shaft lever on 1960 johnson 40hp
    Exactly what are you trying to replace, #39?
    For that, you have to remove the powerhead, and lower unit, then undo all the rubber mounts and remove the #53 exhaust housing from the outer shell. You also have to remove the outer shifter lever to get it back together.
