Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
older cresliner drain plug
  • older cresliner drain plug
    I have a 1961 aluminum crestliner falcon that has the original plug and washer....Are they a standard size ? Can you still only buy the replacement washer? As well i want to replace the washers on the drain plugs...are they standard?
    Re: older cresliner drain plug
    What "drain plug" are you referring to? The ones to drain the gearcase oil? If so, what is the model number of the motor?
    Please no PMs. My mailbox is full anyway......
    • #3
      No they are not standard size
      http://retrocrestliner.com/phpBB/viewtopic.php?t=919
      Life member of POTSOS,
      "Preservation of Old Two Stroke Outboard Society"
      • #4
        Sorry i need the boat drain plug size as well as the two lower gearcase oil washer sizes.
        !970 40hp evinrude 40053A
        • #5
          You can get the g/c washers at any Evinrude dlr, part # 311598.
          • #6
            Thank you.
            Back to Top
