Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Evinrude 9.9 cam follower adjustment
  • Evinrude 9.9 cam follower adjustment
    I have a 1974-76 9.9 evinrude(Model number plate missing).Can only keep engine running if I move throttle plate beyond where it sits at the start position.The carb roller is contacting the timing plate mark but does not open the throttle any further. There does not appear to be an adjustment on the cam follower. Should I bent the linkage rod or does the timing plate need to be moved?
    Thanks
    Re: Evinrude 9.9 cam follower adjustment
    I think the timing plate cam can be adjusted by loosening two small bolts underneath the flywheel. I would avoid bending the throttle linkage. You may even need to get a new throttle cam roller. They form indents in them after awhile and that will throw off the timing and throttle synch.
    United States Coast Guard Officer #1172938
    Catamount Marine
    • #3
      There may be a core plug on the powerhead (looks like a small quarter sized freeze out plug) that has the model and serial number on it. If so, what is it?
      Our Questions Require Answers... If You Refuse To Answer Our Questions... How Can We Answer Yours?
      • #4
        Thankyou for the response. I hope I am replying to this correctly as I have never used a forum before? Anyhow, turns out idle problem was due to engine only running on one cylinder. Cleaned up points and idle is ok at existing throttle position.
        Cheers
