I have a problem, my Evinrude 70hp only starts (cold start) using the Cold start primer solenoid. But once it starts once and engine warms up, I can re-start the engine without using the Cold start primer solenoid.
However, if I disconnect the fuel line and leave the engine works to empty the remaining fuel in the engine/carb, and engine dies. Then if I reconnect the fuel line and pump gas into the engine again I have to use the Cold start primer solenoid to start the engine....
What can be wrong?
Cleaning carb? fuel line? the Cold start primer solenoid? please help
What can be wrong?
