richardbrown67@yahoo.com
- Oct 31, 2010
- 37
On my 1988 70 hp Johnson outboard, I can charge the battery and start the engine, and all is fine.... Good idle, smooth acceleration. Then, after running smoothly for a short while, maybe 5 to 10 minutes, like a switch, the engine cuts to minimal power. Each time this has happened, I have immediately headed back towards the dock, limping along for about 5-10 minutes. Fortunately, I have made it back to the dock, barely. When I slow down to moor the boat, the engine dies. Then there is no battery power to re-start the engine. The battery is new. The battery will hold a charge on its own. The battery only dies if I run the engine as described above.
This reminds me of running a car with a failing alternator - limping along until the battery gives out completely. But the intermittence is puzzling to me. Why will it run really well for a while and then just cut out?
One final thing - just before this problem started I changed the lower unit gear oil using Penzoil 80W-90. The gear oil change was highly overdue. I don't see how this could cause any of the issues about the power, particularly the battery going dead, but, I figured I would mention it.
Suggestions?
Thanks
richardbrown67
Suggestions?
Thanks
richardbrown67
