Re: 2003 johnson 50hp fuse blows
If it only blows when you use the choke, you know it has to be in the choke wiring. Check the wires at the solenoid, follow them back into the harness. I'd guess you have cracked or worn through insulation on those wires somewhere - rubbing and shorting out. Or as the man said, the switch could be bad - I'd check wiring first though.
