The 70 hp 97 engine starts and idles fine. It will run at wake speed for about 10 minutes {With the throttle on max}then sputter to full power, it may or may not drop back to wake speed.Sometimes after it is running you can pull the throttle back,then push it up and there is no problem. If the choke is applied by pushing the key it will stall out quickly. My experience is, if it was the carbs the choke would push it to full power for a second anyway.
Note, Crabs cleaned.
Temperature switch new
Water pump does not pump well at idle, fine with a little throttle
Engine completely professionally rebuilt two seasons back by number one outboard.
compression 120 in all three cylinders
1997 70 hp 3 cylinders evinrude
