MJBennett.FL
- Oct 11, 2010
- 12
I have a 2002 90hp Johnson outboard, with the Optical Ignition System. Serial #: 04986178, Model #: J90VLSNF
Motor turns over real well, spark is good. Take the Air box off and spray fuel into the cylinders and it fires and sounds good for about 5 seconds then shuts off. I am figuring it is some sort of a fuel starvation problem, bad lift pump. Boat never really sat for long periods of time, so I dont think Injectors are clogged or anything along those lines. Primer Bulb gets hard and stays hard, you can see fuel going in when you pump the bulb.
Thanks,
Mike
Thanks,
Mike
