This weekend I went out in my boat, first time since 1st week in August. Motor idels rough and won't run wide open unless I put a couple fingers in front of carb opening. Could this be a problem with the fuel pump?
Thanks for your help! It looks like a big job to remove the carb, as 1 of the nuts is blocked by the starter. Looks like alot of work to remove the starter.
