Always Broke
- Jan 19, 2006
- 162
I?ve had a long time stalling problem with a 1973 135 HP Evinrude, it is slowly getting worse. It will start right up, sit and idle great in neutral and rev right up as soon as I raise the cold start lever but as soon as I put it in gear it stalls, no matter weather it?s cold or warmed up. I keep restarting and putting it back in gear until I can get it to take hold and go. As soon as I can get it off idle it runs great no misses, spits, sputters and has tons of power. I?ve raised the idle speed until the gears would clash with no difference as soon as you put it under load at low RPM it?s like some one shut off the key. I?ve tested compression, spark, timing, fuel pressure, made sure the throttle and ignition timing are synchronized, cleaned the carbs twice (there's no adjustments on them) and couldn?t find anything wrong. Every month or so I would try something different and so far nothing has made a difference, is it possible that I have a leak in the crankcase, would that cause the motor to act this way? I do not see any fuel leaking out but since I run in salt water I keep it protected with WD 40 after every run so it always looks damp. I have access to a smoke machine but was hoping for advice before I go through the trouble to hook it up. Any ideas?
