evinrude 1979 35hp 35952a
Bringing us to moderm times, the manual calls for when using the evinrude cd voltmeter a setting of neg 500 on the cd voltmeter, is that DC volts? for an autoranging voltmeter?
checking the charge coil for output,, when cranking, I should see 230vdc? or 230vAC
