montanamatt
- Oct 2, 2010
- 1
I have a 1972 hp rude that has problems running. When it does run it runs rough. When starting sometimes the flywheel will reverse and engine will run backwards for a bit. I pulled the flywheel and when inspecting the coil it looked fine (green coated one) , but the distributer cap is burnt in two small spots on the inside wall and it smells burnt. Is this culprit to the engine not running well? . -M
