chrome dome
- Sep 24, 2010
- 303
G'day from Australia,
first post on this terrific forum,
l have bought a project boat with a J70TLCNB '82 ( l believe ) 70hp Johnson that hasn't run for a couple of years,
l think? it's a solenoid or starter.. or both.. problem,
pushing in the key gets the click and the carbies opening, turning the key blows that little fuse, is it safe to replace that little glass fuse holder with a newer one?
bypassing the solenoid with a jumper lead on the starter has it engaging and turning the flywheel slowly.. not enough to turn over the engine, BTW should that happen?
with a test light the white lead into the solenoid has power but can't get power to the red lead going to the starter motor,
is it likely to be both or either or am l doing something wrong here..wouldn't be the first time :redface:
BTW, when it's running, carbies will be getting a service,
thanks for any help,
cheers
cheers
