Re: 1972 johnson 65 hydro-electric shift
The correct fluid is "Type C" gear oil. It is now sold under the name Premium Blend" gear oil, by BRP. You can buy Type C oil by Sierra, right here at iboats. Its about a dollar a quart more at iboats than some other sources, but there is a huge benefit in buying from iboats, because most of those other sources, require you to buy a case of 1 quart bottles at a time. You can also use Pennzoil Multi-Vehicle ATF.
The inportance of the coorect fluid is that it acts as a hydraulic fluid, as well as a lubricant. The HI-VIS gear oils commonly used in other outboard gearcases, are too heavy.
If you solenoids are testing OK at the knife blades, both they and the wiring harness in the midsection of the motor are probably fine. That leaves the wiring before that point in question, as well as the shift switch in the remote control.
Here are a couple of tests that you can do.
Testing Shift Selector Switch (at engine)
a. Connect meter or 12 volt test light between green lead (1) and common engine ground.
b. Key switch on. Shift lever in neutral.
c. Circuit shows closed or light illuminated.
d. Repeat test at blue lead (2). Use reverse position.
e. If circuits show open or light not illuminated at (1) or (2), move meter or test light to purple/green lead at terminal block.
f. If closed or illuminated, shift toggle (switch) is bad.
g. If open or not illuminated at purple/green terminal, check ignition switch, fuse and battery.
h. Remove white lead from safety switch (4) and connect meter or test light to white lead (key switch in start position). Operate shift lever to neutral, circuit should close or light should illuminate.
i. If open or not illuminated, move (5) to starter solenoid. If closed or illuminated, starter solenoid is bad.
j. If open or not illuminated, move to shift switch (6) white lead. If closed or illuminated, shift switch is bad.
k. If open or not illuminated, check key switch, fuse and battery.
Testing Switch (inside remote)
a. Connect a multimeter or light between switch green and purple with green stripe leads. If a closed circuit is indicated, push toggle to the left. If a closed circuit is shown, push toggle to the right. If an open circuit is shown, go to step b.
b. Connect meter or light between switch blue and purple with green stripe leads. If am open circuit Is shown, push toggle switch to left. If a closed circuit is shown, switch is OK. If switch is faulty, replace it.
c. Connect a continuity meter or light between the two white wires (for models with neutral cutout function in switch) from toggle switch. Circuit should be closed in neutral and open in forward and reverse.
