I bought this motor off a guy who hit a rock with the prop. This broke the drive shaft off at the top just below the splines. So with the lower unit removed you just look up the shaft housing and can see the broken part just sitting up in the engine flat and as smooth as glass. Question: how do I remove it? Thanks ***Update, removed the broken part see photo near the last post***
