datsunsrule
- Jun 19, 2010
- 25
Hi, I have a 1975 Johnson 40hp outboard that I can't get to idle correctly. I recently rebuilt the carburetor and did not see any improvement. I tried several main jet adjustments, and it idles fine for about 10 seconds, then you can hear the rpm slowly drop until the motor stops running. I did notice that there is a spot on the engine block below the carburetor which is supposed to have a vacuum line attached to it but doesn't. Can that affect the idle?
Also, I was thinking about throwing new coils and condensers on it, and replacing the fuel pump diaphragm. Does anyone have any other recommendations???
Thank you!
Thank you!
