Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
johnson 90 hp - starter problem
  • johnson 90 hp - starter problem
    for a couple of weeks it would just click...so i would tap the starter a couple of times and it would engage and crank the engine. it would run great after that.
    then the boat would sit for a week, and again...try to start...click click click.
    tapped the starter a couple of times and vroooom.
    finally i figured i needed to address the issue, which i assumed the starter needed a rebuild (wouldnt hurt either way)
    got the starter rebuilt....put it on the engine, and turned the key and the starter gear spun like hell.
    so it cranked the engine great a couple of times. then the click came back!
    and now, the starter does not engage at ALL. just a loud click everytime i turn the ignition.
    any ideas on where to start?
    Re: johnson 90 hp - starter problem
    90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
    Be sure the cables area connected to the correct battery post. crossing cables, usually blows the rectifier, and can blow more.
    also have the battery load tested at the auto parts store, free, i've had new batteries go bad
    FLORIDA GATORS
    TEBOW Country
    Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
    That is what these forums are for. Post your questions, in the appropriate Forum.
    • #3
      ok i will check the connections and wires tomorrow.
      the starter has been rebuilt as of two weeks ago. so i was real confused. hah
      so, to jump the start take some jumper cables and connect just the positive battery terminal to the post on the starter? if that works...what should i check?
      • #4
        starter solenoid, iginition switch. battery load tested.
        FLORIDA GATORS
        TEBOW Country
        • #5
          will try and figure it out tomorrow. thanks for the tips!
          • #6
            Banging on a starter is a great way to crack the magnets and eventually destroy the starter. The best practice is to replace the worn parts, especially the brushes. .
            • #7
              You may have a bad starter solenoid. When the contacts get burned over the years, they won't transfer current properly. If you have good starting by using jumper cables, (bypassing the solenoid) consider replacing the solenoid.
              • #8
                agree.
                FLORIDA GATORS
                TEBOW Country
